I bought a hellcat crate this week after several years of dreaming and saving! I'm in the planning stage and collecting parts to swap into my Demon. I will document as much as I can here. I've learned a lot from others' build threads - thank you
I've installed HDK, T56, subframe connectors, and a built 9" over the years, so luckily I have a good foundation to start with. The car currently has a reliably built LA 408 stroker with FI-tech fuel injection that I will probably post for sale here once complete or part out.
I'm mainly in collecting parts stage. The car currently has a LA small block and GM style T56. Does anyone know if bellhousings interchange LA to GenIII? ?
It seems that some brands list them as same part number (quick draw for example), but the quicktime I have list the 2 as different part numbers
Quick Time RM-8074 Quick Time Bellhousing - Small Block Mopar
