I wasn’t expecting to see this post today. This may be a nice offering for the big block guys.
It's about time someone reproduced these.
I also wonder if the quality is as good as they look...
Bushed ? No. Possibly plastic lol!$250 seems too good to be true?
Bushed?
Looking forward to the reviews when they hit the market.
That would be nice.I wasn’t expecting to see this post today. This may be a nice offering for the big block guys.
How many small and big blocks ran them unbushed right from the factory? A lot.We ran non-bushed rockers for years. I ran them
On my .695 mushroom tappet engine for years.
Do you get a cut for atting bighead?
No, but dangit I sure should. lolDo you get a cut for atting bighead?
Lol
Hell yeah you should, your putting in work!No, but dangit I sure should. lol
He's a local friend so I don't mind too much. lolHell yeah you should, your putting in work!
Heck, the stock ones didn’t come with bearings or bushings and worked just fine.Being there are no roller bearing I think personally I would trust these. Heck I went 155mph with their crank and rods. Lol
That's because they came with nanner groove shafts. The failures you see most often are with those rockers put on hydraulic shafts with no nanner grooves AND they also have too much spring pressure. Put those two together and they'll burn up every time. Used how Chrysler designed them and they're dang near indestructible. Especially when they are modded to accept high quality adjusters, like those Mancini rocker arms posted up there ^^^^ those are nice.Heck, the stock ones didn’t come with bearings or bushings and worked just fine.
I have been running ductile rockers on my W2 small blocks for well over 25 years with never a problem only replaced one adjuster at one point.That's because they came with nanner groove shafts. The failures you see most often are with those rockers put on hydraulic shafts with no nanner grooves AND they also have too much spring pressure. Put those two together and they'll burn up every time. Used how Chrysler designed them and they're dang near indestructible. Especially when they are modded to accept high quality adjusters, like those Mancini rocker arms posted up there ^^^^ those are nice.
That's cool.He's a local friend so I don't mind too much. lol
