Hi All, I recently acquired a 1971 Demon 340 which had a recent restoration. There is a bit of an issue with the wipers. They are 2 speed wipers with a 2 speed switch. As far as I know the wiring harness is original. The wipers works in low but stop working in high and when turned off they will not return to home position. I ran the tests of the motor using jumper wires to test low high and home function all properly so the motor seems fine. I tried grounding a wire to the switch housing which did nothing. Below is a picture of the switch connector. Does this look correct for a 71 a body 2 speed? Am I missing a wire in the lower slot? I've seen some picture of a separate 2 slot connector but I do not see this attached anywhere to the harness. Any help would be appreciated. Thanks!
