Wire for Door Jamb Switch
Detroit Iron
California (not a Libtard)
I am trying to find the wire that feeds the door jamb switch. It's a new to me car, AND.... I've had it apart and don't seem to remember.
The panel is a sealed double wall, and so I've been fishing in the switch hole with a hooked piece of wire. Does anyone know if this wire feeds from the floor or above from the dash harness? Thanks for the input.
You should be able to see the hole from inside the kick plate opening.
The wire should be yellow at least in 67.
Single conductor
The red area automatically adjusts as you shut the door.
The green area is where the yellow connector plugs into.
