How much Dyno experience do you have?And that's yet one MORE variable.
I'm curious
I agree the dyno tune isn't always the best track tune. But if you're starting with an unknown combination a good dyno setup and a capable operator can get things to a pretty good starting place. The alternative can be an educated guess or sometimes just a plain wild *** guess.A dyno tune isn’t always a good track tune. Two different worlds.
You may have to do some tweaking when you get to the racetrack.I'll tell you an example, my first pull on my 471 was 601 hp, with dyno tuning it's putting out 682 today. That's incremental small changes with air bleeds, pv's, main jets, transfer slot restrictors, timing changes, distributor curve work, header change, and every time one thing was changed almost everything else needed to be changed.
I'm not bragging at all, just pointing out what Dyno tuning can accomplish.
Well putI agree the dyno tune isn't always the best track tune. But if you're starting with an unknown combination a good dyno setup and a capable operator can get things to a pretty good starting place. The alternative can be an educated guess or sometimes just a plain wild *** guess.
The power left on the table can be less and time it takes to get things dialed in at the track shorter when starting with a tune that has been sorted on the dyno first.
A safe dyno tune may keep you from hurting the motor while trying to get things in the ballpark at the race track. Especially with an unknown motor, unknown carburetor and an inexperienced tuner.
I think the value of a dyno has been proven over the years by the fact that teams racing at the highest levels of competition own and or use dynos.
Honestly if I got 4 passes in a weekend a couple months. It may have been much easier with a single 4 barrel but a tunnel ram with 2 850s was much more of a challenge and really if I didn't have Tim to help me id have been semi lost to start with this thing. We have about 20-25 pulls as of todayYou may have to do some tweaking when you get to the racetrack.
How long would it have taken you to get from where you started to where you are now if you had to do all that tuning at the race track?
Meh....probably about two months worth back in my high school auto shop days. We had access to Mercer University's dyno room for about three years and I spent some time down there peppered here and there. One of the machine shops I use in Macon also has an engine dyno and I sometimes sit in there. It's been a minute, but it's a learning experience every time. Here's his Facebook page.How much Dyno experience do you have?
I'm curious
A lot of them do that, too.The guys that don’t use their own headers, carbs, and electrical systems get me.
I have run into that before. Sometimes they just want it broke in and don't even want a dyno sheet. They just want to know that the motor is ok and not leaking oil. Not how I would do it but for them it might make sense.The guys that don’t use their own headers, carbs, and electrical systems get me.
Some of the motors I dyno will never see a racetrack. Most will never see a dragstrip. Most of the motors I do are for the circletrack. They are not interested in a time slip from a dragstrip but still want the motor to perform to it's full potential.Dynos are great tools. I'm not arguing that. They are extremely subjective because of many factors. The end all be all is the drag strip. I'm not debating their usefulness. I'm just saying one without the other is incomplete.
Right, typical dyno headers will probably not be fitting into a car, if you don't use your own ****... that's just dumb.The guys that don’t use their own headers, carbs, and electrical systems get me.
I always start with dyno headers. I match the dyno header to the customers as close as possible. The dyno headers have Egt probes and o2 sensors in them. At some point, usually after everything is dialed in close I will switch to the customers headers. I loose my egt data but most cases it's not practical to weld bungs in the customers headers for egt and o2s. I have collector extensions with o2 bungs I can use on the customers headers.Right, typical dyno headers will probably not be fitting into a car, if you don't use your own ****... that's just dumb.
Yeah we're going to build some dyno headers with egt probes for big and small Mopar. Chevy guys will have to bring they're own junk since they can pick it up at 7-11.I always start with dyno headers. I match the dyno header to the customers as close as possible. The dyno headers have Egt probes and o2 sensors in them. At some point, usually after everything is dialed in close I will switch to the customers headers. I loose my egt data but most cases it's not practical to weld bungs in the customers headers for egt and o2s. I have collector extensions with o2 bungs I can use on the customers headers.
Is it for personal knowledge?I won’t mention any names but a frequent Moparts poster from I think the Midwest states always wants a double correction factor. He want the dyno correction figures and he wants a factor for the state his engine was dyno’d.
Bragging is stupidNo it’s for a bragging spreadsheet
When I had my engine on the dyno over six years ago it cost $400, the best money I spent on the entire build. My engine was built to run on pump 93. We broke it in and tuned it on leaded 98 race gas, then switched fuel to the 93, it made 30 more hp on the first pull with no tuning. We cooled it off and made another pull, with the same results.
The bottom line a dyno is a tool, just like a tire pressure gauge or a flow bench. I get a laugh out of guys who claim dyno numbers serve no purpose but swear by their head flow numbers and never see the irony.
