Would this work? Needed to splice between intermediate line and rear discs. Removed hose securing bracket for proportioning valve.The valve will be bolted up keeping it from moving. Will the flexible hose be ok since it secures to a fixed hard line?
IMHO really bad idea.The valve will be bolted up keeping it from moving. Will the flexible hose be ok since it secures to a fixed hard line?
If you are saying nothing should be allowed to vibrate by being properly retained then I agree. If you are saying that the OPs setup in the photo won't vibrate... I would have to strongly disagree.Nothing should vibrate
