boosted
Life Needs Air
What other year dash will bolt into a 70 Dart.. The guy I gave the dart to would like to replace with a stock dash and does not care if it is period correct.
And wiring may be differentNow to be clear, you have to swap the entire metal dash assembly
1970 was the first year for ignition on the column.And ignition switch got moved from dash to column around 70 or 71
