20 degrees is a lot. I didn’t think they bled off that much. Then again, I may have just forgotten!A few. Bout 20 at low RPM. No wonder you have high cylinder pressure.
That's pretty easy to solve, just retard the timing during cranking.I’m starting to think that way. A side issue is it’s hard on the starter.
Yeah, I was thinking along those lines at the time - like a simpler VVT.As to your Rhodes lifters. IIRC you can tune them with oil viscosity and/or oil-pump pressure/volume.
IMHO, I think if a guy worked with them, they could make an excellent street-strip combination; like a poor-man's VVT.
I shouldda tried them on my 292 cam but I wasn't smart enough back then. (1999)
Possibly with a lower compression street engine (maybe 9.5:1 or so?) they would be more suitable.
I probably should have put a solid cam in this engine.
I always thought the point of them was to use the right cam for performance while having decent driveability, so don't have to compromise.IMO they are never suitable. If the cam is wrong you can't fix it with a squishy lifter. Like I said, yuou can run way more compression on pump gas than the smart people say. You just can't cut corners.
Agreed. Actual timing events take precedence over lobe duration & lifts. I know more about this stuff now than I did 7-8 years ago.Generally my choice. If you choose this path, because you are up against cylinder pressure, pay particular attention to actual valve events verses lobe events.
Dumb or not it's probably the thing most are concerned with, with a street car. How many times the argument here where's the right line for X mod between performance and driveability for the OP's.Driveabilty. The dumbest undefined term ever.
Yup. That's about the rate.20 degrees is a lot. I didn’t think they bled off that much. Then again, I may have just forgotten!
I think if you had a lower comp street engine with a healthy cam in it, they could work very well if the engine was spec’d out properly.Dumb or not it's probably the thing most are concerned with, with a street car. How many times the argument here where's the right line for X mod between performance and driveability for the OP's.
It is concept (streetability) I'm buying into less as a factor.
IMO, it depends. IF all I am doing is building a 100% street car just for cruising and having a good time with, while I do look at valve events, they are not my end all be all guide. No way. No how. It's real easy to get caught up in "paralysis by analysis" looking at too much. Now a race only or hot dual purpose car, I'll spend some time on. But something for the street? I make a decision and go have FUN!Agreed. Actual timing events take precedence over lobe duration & lifts. I know more about this stuff now than I did 7-8 years ago.
Or even go bigger camI think if you had a lower comp street engine with a healthy cam in it, they could work very well if the engine was spec’d out properly.
Higher compression, learn from my pain!
Search some of IQ52's builds on here. Specifically what they did with a 7.35:1 440. Yeah, you read that right. He's proved time and again compression is not the end all be all. I try to preach it all the time, but get argued down so I just give up.I think if you had a lower comp street engine with a healthy cam in it, they could work very well if the engine was spec’d out properly.
That would be my choice. With NO Rhoads lifters.Or even go bigger cam![]()
Now you’re talking!Or even go bigger cam![]()
Eg. a 12's low cr vs 12's high cr car, both are still a 12's (or whatever) car the high cr probably feels stronger but you still can go fast with low cr.Search some of IQ52's builds on here. Specifically what they did with a 7.35:1 440. Yeah, you read that right. He's proved time and again compression is not the end all be all. I try to preach it all the time, but get argued down so I just give up.
Thanks RRR, I’ll check it out. We get talked into high compression by the ‘gurus’ sometimes I reckon. You don’t really need it.Search some of IQ52's builds on here. Specifically what they did with a 7.35:1 440. Yeah, you read that right. He's proved time and again compression is not the end all be all. I try to preach it all the time, but get argued down so I just give up.
It's certainly true. The forum gurus and all the magazine articles have you believe your junk won't even fire off unless it's at least a flat 10:1 and it couldn't be further from the truth. The ONLY reason my slant 6 turned out with 10.6 is because the head fell off the broach on one end and I had to get that milled out on a Rottler. The chambers went from 59cc to 34cc. I had to utilize the head, because all the others I had needed seats and guides and that one did not and I couldn't afford that. So I chose a camshaft with a 71 degree IVCE. Now THEN I looked at the valve events, because I needed to in order to run on pump gas. Otherwise, I would have had the "obligatory" .100" milled off the head and been "around" 9:1. I think it ended up close to .180" milled off to get it back straight and clean. It was a lot.Thanks RRR, I’ll check it out. We get talked into high compression by the ‘gurus’ sometimes I reckon. You don’t really need it.
I spoke with a few ppl when putting it together, in AUS & U.S. One a local Pro-Stock builder. The general consensus was you have 10.7:1, great quench, run it. In reality, it’s probably a bit high.
Unless your use to running on the edge with CR it's probably better for most to give themselves a bit of a safety margin, especially since point of CR gives a fairly small reward hp wises, eg. around 3%.Thanks RRR, I’ll check it out. We get talked into high compression by the ‘gurus’ sometimes I reckon. You don’t really need it.
I did mention to these ppl I spoke to ATT, I thought I was getting close to the edge for pump fuel or at least a decent safety margin. They strongly disagreed, I understand why but there’s a point where it becomes impractical & risky.Unless your use to running on the edge with CR it's probably better for most to give themselves a bit of a safety margin, especially since point of CR gives a fairly small reward hp wises, eg. around 3%.
Yeah I know that. The solid with the same duration "acts" about 10 degrees in duration smaller than a comparable hydraulic. I didn't seen anyone bring solids into the conversation. Maybe I missed it. Since he has a hydraulic, that's all I was discussing. I didn't see any need to muddy the waters.The point was you cannot directly compare SFT to HFT specs. He has a detonation issue with the 100% street car he already has. Should probably try to not make the same mistake twice.
