Stop in for a cup of coffee
I am very happy with it, has plenty of power for me.....................:thumbsup:
I did notice it was pulling HARD left yesterday when applying the brakes.
Mine had a little pull to the right yesterday as well. May be a drop or two of brake fluid or 80/90 found it's way to the drum over the winter.
Morning!
Barely froze last night, double digits today. There is light at the end of the tunnel.
Hope to make some good progress today, but i will likely end up sitting on tractor and scraping driveway. Get rid of the slush so it will dry up.
Eric what Ign you plan on running
I am not sure yet. I have the Pertronix (IIRC) that Dad had on the engine for now. Not sure what the best avenue will be when it is time to go fast. The original plan was to leave the motor as is, lock timing out to limit cylinder pressure spikes and add C16 or Q16 fuel and 18-20psi boost. Need reliable spark up to 7000rpm, will rev to 6000 though likely
Wow! there was a house explosion in town last night. It was a few blocks away from our other house.
I may take a car for a spin today. Ankle not quite ready to trudge around cutting brush. Have to keep my mind busy today
