Even a complete novice would pick up on an engine with jumped timing, because the sound of the engine is vastly different when the timing chain jumps even a single tooth.
NSS won't preclude spark, it only disables it from cranking via the key in gear.Wouldn’t something electrical (like neutral safety switch) disable fire to the cylinders?
Yeah, good luck with that.NSS won't preclude spark, it only disables it from cranking via the key in gear.
which all of that hooey could be eliminated with a few jumpers and a remote starter switch to isolate where the problem exists and narrow down the focus.
I just pulled all 8 plugs . Look nearly new & dry . I cleaned them with a small wire brush . I am getting a good spark in between the plug points when turning the engine over . Also , I felt gas spray out of the plug hole in the block . Moving the throttle back shoots a good stream of gas into the carb . I have replaced the neutral safety switch with a new one . I will have to get some starting fluid & give that a try . I am working by myself , so it is to hard to test voltage while turning the remote starter trigger .I’m sure someone will correct me if I’m wrong, but this pretty much indicates that he’s got spark and the timing hasn’t jumped. I think one of the above posts about using starting fluid is a good idea and cheap and easy. If that makes it start, then it’s fuel, if not then I’m stumped. Wouldn’t something electrical (like neutral safety switch) disable fire to the cylinders? Hopefully this was suggested a long time ago, but is the accelerator pump discharging fuel when the throttle is actuated?
I have good spark in the plug gap . Plugs were not wet . I only drive around 1500 miles a year & the plugs , wires , cap , rotor , points & condenser were new only a few years ago . Not enough milage to wear anything out . I have been retired for 17 years & by myself now . No one around to add a extra set of hands . I need and extra set of wheels as backup to my 1977 Dodge D-150 half ton pick-up truck . I bought it new in 1977 . 318 engine , automatic .remove the number one spark plug. Put it somewhere that you can see the plug gup and make sure the plug is grounded. Crank the engine over and make sure you visually see a good spark there. You can replace all the parts you want but the plug gap is where the spark has to be to ignite the fuel.
Actually, you should never use vaseline on electrical contacts, vaseline is an insulator, not a conductor, it does NOT conduct electricity, it actually prevents the flow of electricity. Instead, you should be using dielectric grease, it both helps prevent corrosion, AND allows electricity to flow freely.this is my list of corroded green connectors all of which looked great until you pulled them apart, all of which have worked again perfectly well for the last 20 years once cleaned and smeared with a thin layer of vaseline
Make sure you wash the contact cleaning "products" off before you vaseline it up for the next 20 years....
Dave
Dielectric grease is also an insulator, look it up if you don't believe meActually, you should never use vaseline on electrical contacts, vaseline is an insulator, not a conductor, it does NOT conduct electricity, it actually prevents the flow of electricity. Instead, you should be using dielectric grease, it both helps prevent corrosion, AND allows electricity to flow freely.
I used vaseline for years too, until I got schooled. Look it up if you dont believe me![]()
Looks like I learned something today! I did look it up, and it turns out that dielectric grease is better than vaseline though, even though both are non-conductive.Yes it is. I had a maintenance guy back in the 80's smearing a thin layer of dielectric grease on 3 inch hockey puck diodes in a Dynapower DC rectifier. It smoked everyone of them and we couldn't anodize anything until I could order a complete set and resurface all the copper compression conductors that pinched them in the rectifier. Dielectric grease is definitely an insulator!
To be done correctly, the carburetor should be held open to allow full flow without restriction. At least that is what I have been told and do.I tried the starting fluid and the engine did NOT fire up ? My Dad was a diesel mechanic . I have his tool box . I remember seeing some large dial gauges . Maybe one will fit the 18 m/m hole in my block ?
Found my Dad's compression gauge . I removed all the plugs and held the gauge firmly against the spark plug hole in each position . Used the remote starter to compress each hole . It averaged around " 60 " between the 8 plug holes .
I was thinking the same thing...LOL Eddie Murphy may have been lurking around the neighborhood.Not sure if he really checked if jumped
Did some stick a banana in his tail pipe.....
Funny backed into a dirt ditch
Clogged tail pipe
Took a while to figure it out
Dielectric grease is also an insulator. It is to be used to seal the connection from the elements, not to put on the metal terminals just the boots or other sealsInstead, you should be using dielectric grease, it both helps prevent corrosion, AND allows electricity to flow freely
It was 3 or 4 pumps to get it up to 60 ish . I have turned the crank shaft to TDC and the rotor points to the #1 position , front left side of the engine .How many “pumps” on the compression gauge to read 60psi?
If it’s like 4, and the gauge is accurate…….. I’d be thinking the timing chain jumped…….especially if they’re all about the same.
