When the shut down they will kick back a little and jumpThat is how I've had the chain die twice. I don't know why, just that it's not that uncommon.
Ok .With key off , both sides of the ballast resistor has no voltage .
With key on , I have 10.5 v on the engine side and barely moving the needle on my volt meter on the outside .
Remove the yellow wire from starter relay and key on , I get 10.5 v on the engine side and barely moving on the outside
I've never trusted the compression testers like you used. The rubber ends always get hard and fail to seal. You need the screw in type with the o-ring on it to seal good. You can get one from any auto parts store's rent a tool program and get your money back when you return it, or just buy one. Having two older vehicles, you should have one in your toolbox anyway. I would recheck compression with one of those and report back. Although sure, it's possible the timing jumped, I put that on the very last list of things that has happened. I'd want to eliminate a faulty compression reading first. It's always best to verify.I replaced the points & condenser inside of the distributer after it would not start the next morning .
Could the chain jump the next morning while it was running fine when I cut it off the night before ???????????
Engine was rebuilt in 1995 by Little & Jenkins in Roanoke Rapids , North Carolina . A major engine rebuilder for the east coast . Left the car and they removed my engine , rebuilt it to factory specs and I picked it up about a week later once finished .
Are the points adjusted correctly? Close points all the time will over heat the ballast.Ballast don't matter it just a resistor
They do get hot if your points are closed
Might be a bad coil making spark but not enough to fire a plug
Even with the timing jump, you would have some type of miss-fire or pop. I'm not sure on this car but were the timing gear teeth steel and not nylon as the later tears? Steel gears should last longer than 146,000 miles as this car is and as a daily driver. I'm looking more into the first problem and not the one now. Were the points pitted and or locked up. That could be the start of the problem and not setting the points correctly, could be the problem now. I have a duel point in my stock 340 4-speed and it takes me an hour to set the points correctly, with even taking out the distributer, in and out several times. Setting the points correctly with the distributer up against the firewall, I would find it difficult to do. Not sure if it matters, but it looks like the coil is up against the vac. canister on the distributor.Even a complete novice would pick up on an engine with jumped timing, because the sound of the engine is vastly different when the timing chain jumps even a single tooth.
That was my reason for asking if the points were pitted or fried together, when removed. The ballast also looks brown as it was over heated.So maybe it's remotely possible you left the key on and burned the points up.
Engine was rebuilt in 1995 . Probably less than 20,*** miles since that time . I do not know if it has a steel timing gear ? I did turn the crank shaft to TDC and the rotor points to the #1 cylinder . Front left side of the engine .With that many miles on the engine and assuming the timing chain and gear are original, the problem is likely a broken timing gear. What year did they stop using the nylon coated timing gear on the crankshaft? I just went through this same issue with my Poly 318. It was easy do diagnose by removing the distributor and spark plugs and then rotating the engine back and forth manually roughly 20-30 degrees. If the gear set and chain are intact, the rotor should rotate both directions immediately as you rotate the crankshaft by hand. When the gear is broken, there will be a delay in rotor rotation when you change direction of crankshaft rotation.
UnderstoodEngine was rebuilt in 1995 . Probably less than 20,*** miles since that time . I do not know if it has a steel timing gear ? I did turn the crank shaft to TDC and the rotor points to the #1 cylinder . Front left side of the engine .
and is the plug wire for number one lined up with it at that point? Has the distributor been turned enough to miss the fire?Engine was rebuilt in 1995 . Probably less than 20,*** miles since that time . I do not know if it has a steel timing gear ? I did turn the crank shaft to TDC and the rotor points to the #1 cylinder . Front left side of the engine .
I do not know ? I do not even come close to being able to rebuild an engine . All I was told was it was rebuilt to original specs . That was 1995 .He says someone rebuilt engine
Did they use correct dampner
