Sorry it took so long to respond to your question about tips to help. Well I just pulled everything out sand down to metal, welded, primed, body filler, primed, sanded and painted. I even pulled the K-member. I stood in the engine bay to paint so I had to be careful not to back into the car as I painted one side or the other. I did weld a few holes up, weld plate where the wire harness goes throu the fire wall, reason for the is I plan on using Painless wire harness.. And from what I understand it does not have a bulkhead to go throu the fire wall, just a rubber garment. So when I get the harness I will just drill a hole insert the harness and use the garment. Here is a link to my bay. If it works here is the link. good luck.
http://www.forabodiesonly.com/mopar/showthread.php?t=31368
