1wild&crazyguy
Banned
was the oil slinger installed backwards?
and does the dampener still have the metal bell pressed around the snout?
you can pull the fuel pump to see if the eccentric is loose, 4wiw
I've see where the eccentric comes loose and rides against the cover and in a matter of time cuts through and =water in the oil
