mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,242
- Reaction score
- 130
How would you build a 360LA with the following restrictions and with a goal of a mid to low 13 second street car at 3600lbs
- Stock bore, and stroke (and pistons preferably too)
- 3.00 rear axle ratio
- must run on pump gas (87 octane preferably, but 91 is an option)
- max budget of 3k for engine and converter (727)
- ability to retain power steering and brakes (brakes not a MUST, but would be nice)
I have a lot of LA parts kicking around already (gaskets, bearings, ignition, trans, carb, etc) and have done a low budget build like this before, but not on a vehicle this heavy, nor with this kind of gear ratio restriction. Trying to do it on a budget, so going to try and piece what i dont have together using second hand parts.
So, how would you do it? Or have you actually done it?
