360 Magnum, Accel Super coil, MP distributor, MSD6AL, stock compression, streetish cam
Im reading . 45 thousandths for MSD boox
Start at .040 and with all that MSD spark, you'll be at .045 before you know it.I'd start at .040 if it was mine. 45 should be fine thou.
It’s gotta be because your shoving more energy down the wire to make the spark jump the larger gap.Another issue that I noticed was that
the spark plug wires tended to go away
in about 1/2 the time. I had to replace they
every year.
I do not know why but they did degrade much faster.
.045 is a good start. What’s the compression ratio? Higher the ratio the lower the gap.360 Magnum, Accel Super coil, MP distributor, MSD6AL, stock compression, streetish cam
MSD 8.8 WiresGTX John,
What type of plug wires do you claim were 'going away', needed yearly replacement. What symptom of failure were you getting. I have spiral wound MSD wires, been on 20 yrs & see no deterioration with 060 plug gaps.
the Amp didn't last very long.Aaaaaaand ….????
How did you like it?
@AJ/FormS Thanks AJ. If you’re ever up for selling it, look me up.
Which exact model is the Jacob’s ignition?
PRO-STREET energy pak, 826-72-580@AJ/FormS Thanks AJ. If you’re ever up for selling it, look me up.
Comes with adjustable Rev-Limiter, by hundreds to 9900.
on the base is 37050-8/3240 A
anodized blue.
