Front of the instrument panel ready. Next the backside. I found the cover lock for the fuse box. But is there a cover lock for the push bottom mecanism?
The speaker on this one was dead. Will glass bead it and a new coat of paint.
The clips that hold the wiring to the neutral start switch was there. Restored the cable and mounted it the way it was installed.
Even the driver side exhaust manifold brackets were there.
The accelrator wire is mounted in place too.
