1964 Dart GT convertible
Front of the instrument panel ready. Next the backside. I found the cover lock for the fuse box. But is there a cover lock for the push bottom mecanism?
Finally the steering column is assembled and ready. I found a little hook to told the wiring in place. Never seen it before.
Top of dash painted. What a differens compare to shiny black. Adding speaker and wiring for it and we're ready.
The speaker on this one was dead. Will glass bead it and a new coat of paint.
The clips that hold the wiring to the neutral start switch was there. Restored the cable and mounted it the way it was installed.
Even the driver side exhaust manifold brackets were there.
The accelrator wire is mounted in place too.
It's all in the details!
