1967 Barracuda Fastback. VIN indicates it came originally with 273 Commando/4spd. Has 489 rear end with 323:1 SureGrip. Car had a running 340 in it when I found it. Needed a lot of sheet metal work up front since someone had bent the lower radiator support and cut huge square holes in the inner fenders. I assumed for fenderwell headers.
The hole in the firewall where the clutch rod exited had been lengthened downward. Door strikers were kinda welded in place. Had to take two driver side...
Log in or register now.
