This is a factory sway bar assembly off a '67 formula S with the 383, so it's a big part of the heavy duty suspension. When I got the car in '04 it was installed in the trunk and and didn't seem to be helping the handling. I'm very new to the Mopar hobby so I thought I'd post what I learned on this portion of the resto. Center bend in the sway bar goes UP. If you want to use the factory brackets you HAVE to cut them and PRY them open. You WILL need lube to get the old bushings off. Sand...
Log in or register now.
