Less than 500 miles on the Fresh 440. 425 - 450 HP
NOS Block was bored and honed .020 with deck plates, steel crank polished, reconditioned rods, and assembly balanced!
New: Nitraded COMP Cams Xtreme Energy Hi-Lift Cam 525 lift / 232 duration, 9.5:1 Keith Black forged dome shaped pistons, Sealed power piston rings, Clevite main and rod bearings, Smith Brother push rods, COMP Cams Pro Magnum Shaft Mount Roller Rocker Arm assembly, COMP valve springs and retainers, Johnson lifters...
Log in or register now.
