This is my 1973 Dodge Dart Sport. It has a 512 with a 440Source rotating assembly, Eddy aluminum heads, Eddy Performer RPM intake and a Pro System 950HP carb. It has 10.55:1 comp. and is balanced and blueprinted. It includes Schumacker Tri-Y headers and a Comp Cams 564 lift hydraulic cam. Behind that is a TCI 3500 stall converter connecting to a 727 with Mopar Performance internals. In back is a narrowed 8.75 with 4.10 spool. The car is mini-tubbed with the springs moved inboard. The front...
Log in or register now.
