1973 Dodge Dart Swinger MOD
1978 360 replaced /6, Shumachker mounts, stock bottom end other than the anti leak rear main bearing, custom baffled stock oil pan, Hi Volume oil pump, deburred the block, heads have been given just a basic overhaul, new guides seals, 3 angle grind, emmisions ports plugged.
Optima Red top
Stock distributor stock black box electronic ign.
Stock coil, new plug wires cap rotor and plugs
Edelbrock StreetMaster single plain good from about 3000-7000 rpm
Crane C...
Optima Red top
Crane C...
Log in or register now.
