66 plymouth valiant signet
here's my car still in progress.
motor is a 360 bored 0.040 over, stock bottom end, crank was polished by hand, stock rods and pistons. heads are 360 castings re-worked with 2.02 intakes, and milled 0.038 thousandths, set up to handle a .520 lift with 1.5 aluminum roller rockers and a slight port job on the bowls and intakes. cam is a hydraulic .509 lift w/292 duration running anti-pump lifters. trans is a 904 race prepped w/manual valve body, and a 3800 stall converter. it still has the 7...
hollywood hig
More from hollywood hig
