1987 Dodge W100
Dana 60 kingpin front
Dana 70 rear
5" rough country lift
16x12 Weld Scorpios
35x12.50 Bfg tires
4.10 gears 727 transmision np208 transfer
383 from 66 charger
Bored 30 over
Xe274h comp cam kit 911 valve springs
516 heads bigger valves and blend
KB flat top pistons with valve reliefs
Arp rod bolts
10.1:10 compression
Dana 70 rear
16x12 Weld Scorpios
35x12.50 Bfg tires
383 from 66 charger
Bored 30 over
Arp rod bolts
10.1:10 compression
Log in or register now.
