[SOLD] ‘68-‘69 Barracuda AM Radio
haywire 440
Central South
This is a bench tested radio. Comes with the mounting bracket and nut. Very nice looking, volume-tuning-tone-push buttons operate correctly. Radio stations come in and the thumbwheel dial chrome is in great shape. Dash light works and that plug is solid. Perfect candidate for stock dashes or the Aurora conversion. This is $115 plus the shipping and is located in Illinois. More photos in the next post.
This is a closeup of the power leads with color tape over the insulated wires. Wires all function well but I want to show all aspects of this units shape, power and speaker wires and connections.
I won't swear to it, but it does not look correct for a 68-69 Barracuda. The front chrome bezel does not have the upper long left bracket to mount in a rally dash.
You seem to be on to something here. I originally went by the part #2864515 and just looked this up on a radio id site. I see chrome push buttons and that upper left mount. Good catch @blewbyu, now I wonder what it is. That top plate w/# could have been mistakenly switch.
At one point it could have had been for a 68/9 cuda. It needs to have the proper front panel, which could be added/removed as needed. I have seen C body radios that look very similar but the profile has a " lean" to it.
Post a pic from the side
Well they both have the same part number. So I think the front chrome bezel must have been changed. So it would need that as it is the mounting point on the drivers side.
I believe dart used the thinner black plastic buttons. I have a 68-69 valiant radio I converted to a barracuda radio with custom made LH mounting tab.
Here’s some side pictures and pictures of a c-body radio parts. Also included is the c-body tuner & push buttons, this assembly is longer to make up for the slant and extended front plate.
I will be ending this sale shortly but wanted to answer all inquiries. Also thanks to all responders for the heads up on my mistake and the quick lesson.
