Ω OHM range empty/full for fuel sender 67-76 Darts
67dartgt-440
Member
does anyone know what the FULL and EMPTY ohm range readings are for a stock fuel sender for the 67-76 Dodge Darts? I want to install an autometer fuel gauge and my sender might be bad.
These specs apply to the 67-69 darts as well,and can be adjusted by bending the tabs to get the spec needed,with in limits.Do be sure to attach a graound strap from the tank to the body for a permanent ground,to make sure the guage works,Mrmopartech
