1/2" fuel sending unit
I had to make my own.
I don’t have a part number but try searching eBay, Amazon, summit or jegs, Mancini or hughes
Make a cage out of screen. You just need to stop large pieces of debris that may get into the tank from blocking the end of the tube. Put and inline filter before the pump.
Put a filter before and after your fuel pump. You don't need a sock filter in the tank if you have that, and I wouldn't rely on one of them for that purpose anyhow.
You can install Holley's Hydromat and gain the benefit of a 10 micron filter and enhanced fuel pick-up at lower fuel levels if you have the $. The smaller ones are less expensive and still work well.
