moturbopar
Hi all Im looking to find out what and if there are any 1.5 ratio rockers (ford/chevy?) that will work on a magnum head, with the correct conversion studs, and guide plates.
Guys, so I can put a set of Chevy roller rockers in the Magnum heads? Any type of Chevy rockers? Could you recommend a good 1.6 combo with a good price? thanks!
they just want to look at the pics stroker.lol:violent1:Read the whole thread. Then replace the 1.5 rockers in my link above with 1.6.
Damn, why don't people read all of a thread?
You do realize that due to the complex angle of the pushrod to lifter to rocker arm on SB Mopar's (look at it from a front view and you'll see their not in a straight line) that you won't get the advertised lift, right? Even with perfect geometry you can figure you'll loose .025~.030 lift. Would that put you where you need to be? If you think so mock it up and measure the actual lift to see what it's got. My guess is that even with 1.6 ratio rockers you'll actually only have about .515~.520" lift at the valve.
So Fishy,
If I had a cam with lobe lift of .342" what lift at the valve do you think I would get with 1.7:1 rockers on a magnum head?
