805moparkid
Slant and AFX Guy
is it big enough for say 300hp and 550tq on the street?
I would say run it.
A quick google search proved thst many 90ci blowers are used on ford 3.9L V6 engines running 11sec 1/4 mile times.
Yeah, the ford and buicks with 3.8L used 62ci and 90 ci blowers.
The slant is almost the same volume at 3.7 L.
20psi out of a 1.5L? can it be done?
I'm not saying it can't but, as mentioned above, boost is a function of restriction. If you're pushing an M90 head unit into a stock 225, very likely, but it'll heat up the air quite a bit and you might actually hurt the power capability.
As soon as you up the duration and lift on the cam, or port the heads, uncork the exhaust, or some combo thereof, it alters the efficiency of breathing of the engine, and can actually drop the read boost pressure, despite the fact that its pushing the same amount of air...
Fwiw, good D/A, pullied up M112s can push 18-20 on stock 4.6 Cobras, but it's really pushing the limits on the blower itself, so an M90 or equivalent probably can push that on a 225
Oh-I forgot about a coworkers GTP...he ported his blower housing and throttle body, pushed 300 hp at the tires...don't recall a boost number, but that Grand Prix would move along pretty damn well
are the 4-71's the same bolt pattern as the M90? i would rather not have the blower on the edge all the time.
also yes i understand what boost is, and as the engine is more mechanically efficient the boost number will drop. so i guess i should have asked im looking for about 300hp and 550tq.
hmm nice! i'll be doing a blower cam , 8-9:1 comp, head work, etc...
as i said i would like to get a 2700lbs car into the 10's... street driven!
I can't really answer that, because the M90s were made for a few different apps. And 4-71s were usually made for V8 intakes...but if you have access to some sheet aluminum and are good with TIG, you could likely fab up whatever you want.
Didn't mean to insinuate you didn't know what boost is; I guess I interpreted the first couple posts incorrectly-anyway, I don't know that you can get that much torque with that hp level based on a 1.5L roots type blower, out of a 225, but hell-give it a shot if you have the chance
If you match the 300rwhp with a 2700lb car, it should be close-as long as the suspension is setup right...but I'm not a good estimator when it comes to that
Regardless, it should be a load of fun
There was a fella from my home town-well, he raced at the track down the road from my hometown-a Duster with a slant...ran mid 11s, N/A IIRC, but we're talkin a gutted Duster and a uber pissed off 6...if you were by the traps at the 1/8 when he passed, your ears rang for a few minutes.
I like the thought of the 471. I think it would be more conventional and easier to find parts for. JMO
