crazy 340 Well-Known Member Joined Jan 6, 2008 Messages 816 Reaction score 61 Location quebec canada Jun 13, 2014 #1 dump question how do I wire it what do I do with the 2 field wire???
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,975 Location las vegas Jun 13, 2014 #2 you have an One Wire alternator...Battery post only and no fields on the alternator... run that one wire to the battery or the battery terminal on the starter relay switch.... make sure that wire is the correct size...the field wires...you can cut them...tape them...basically not using them..
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,620 Reaction score 34,107 Location Idaho Jun 13, 2014 #3 I might ask how big (output amps) is the alternator and are you trying to use a factory Mopar harness with alternator? "Bad idea."
