[WANTED] 10 1/2 cast bell
That might a bit tough to find. Technically it's '64 only with a big block (not a 426), though you should be able to make the '65 version work....not sure what the difference is. For a small block, you're on your own as they didn't make one that year (or '65) with the 10 1/2" clutch. Using a later one would require modifying clutch linkage and maybe a different clutch fork and/or pivot.
Yes for Big Block, sorry but I have no cast number, Actually I bet the 65 would be perfect.
Brewer has them, just looking for one a little less expensive!
The 833 didn't start until '64, so, I have my doubts about anything '63 and earlier working.
Casting# you need to look for would be 2463019.....1964 B-body ONLY... 361/383/413/426 wedge
VERY RARE and VERY EXPENSIVE......IF you can find one!!!
I have no concern as to the correct number as long as I have a bell and fork, etc. that works on my 64 Savoy. Probably just go thru Brewers that way I know what I buy will work. 10 1/2 in. cast bells are always cheaper and easier to find that 11 in. aluminum.
