ian
- Joined
- Aug 23, 2008
- Messages
- 412
- Reaction score
- 54
yes it is hard with street car ,but practice makes perfect. whats your combo mateI am in the 9's it is not easy took me some time but those indy heads work
thats tuff as and well done , i need big tyres as well1965 plymouth belvedere1 2dr sedan 9.81 @135 mph 135 60ft through mufflers timing @ 32 degrees on foot brake. 496 with stock UN ported 440-1 indy heads No spray on trans brake with timing @38 degrees muffs off car will go 9.50. Car is 3300 with driver
yes i am from ballarat mate , i went 10.60@127 with j heads and 150 shot with std springs,shocks ,valve train now 8000$ later car gone 10.30@132, lot of $ for little gain but when i run a nine it will be worth it:-Dhey are you from ballarat? think we chated at calder one time, it had ruffer paint n a iron 360 on n2o, 10.80 10.90 back then. mine is big block now
http://www.moparmarketforum.com/forum/viewtopic.php?f=31&t=15865 it had a hemi 6 back then, with no traction it went 14's. now with the 440 it'll smoke 275's at anythin under 45mph.=P~
yes that was in full street trim pipes up and nitrous timming and tow bar for when i get wood , 10.95@122 pipes droped and sill tunning itIan!
Saw pics on fullboost of your car at heathcote recently!
Time i saw i think was a low 11 at 120 mph?
No spray?
Let me know!
pump fuel 259 flat tappet 580 lift 3.9 rear 26/10 ,904 4300 stall indy heads ,1 3/4 pipes 3550 lbs car still plenty ot power in this engine aspirated at least 100 hp ,we get some of that next yearAn whats your setup moparforlife?!
Does it ran on pump fuel?
What sort of cam etc.
Love the car!
cool, might be there on the 26 let me what ya race ,i will come up and say hi
