10" front drums
SpeedracerX
Still on this side of the dirt member
Irwin, Pa
Rating - 0%
0   0   0
Hiya gang...
Just curious if anyone out there has a set of 10", small bolt pattern, front drums with hubs and studs intact... the studs need to be right hand thread. 2 of the studs in my drivers side drum were broke, and went to 3 differant part stores, the stud they have listed just does not fit.. the shank is apparently to narrow.. so I had the studs welded in.. already had the welds fail once.. If anyone can help.. I would appreciate it..
I'm gonna hook you up duder, call turners auto wrecking in fresno ca
[559] 237 0918 he has almost everything but will be retiring so to speak sooner than any of us would like.
He ships expediently also.
Good luck.
