FlyingFalcon
Like the title says, I need either a Driver's Side 10 Inch Drum Brake Set Up, or a Small Bolt Pattern Disc Brake Setup. I put the new tires and wheels on my car today, and come to find that I only have one 10 Inch Drum Brake. A previous owner had swapped out the Driver's side with a whole different 9 Inch Setup. :banghead:
I'm in Yulee, FL. Close to Jacksonville. I can't afford completely a redone set up, looking for a driver quality. On a budget.
Thanks FABO
Thanks FABO
