This is a complete SBP 10" drum front brake package from a 68 Barracuda. Correct LH and RH threaded drums with plenty of material left for a re-grind. Appears that even though these have set for awhile, there's not many miles on them; the drums have no ridge from brake pad wear and the brake lines I removed were newer ones with no cracks and not dried out. Check out the brake shoes, look almost new. All springs also look good and no evidence of the brake cylinders leaking. Backing plates are also in good shape. Bearings and lower ball joints look questionable so may need replacing. Rubber boots on ball joints for sure need replaced.
$175 for all, plus shipping from 57004.
P.S. - I have the upper control arms listed in another thread if you also need those to complete the package. If you want the UCA's, total package would be $200 plus shipping.
Thanks for looking!
Thanks for looking!
