10 "x 1 3/4 pad x4x5 bolt p. drum available?
cmac64dart
mays landing nj
Looking for a 10 drum to fit my new 1 3/4 " pads. I bought pre loaded brakes a long while back not knowing these drums were hard to find. Guess I could look for a 10 x 2 1/2 set up or go complete disks but read that the disks would require me to go to a larger rim. I'm running 14 inch rallies. I'd rather not change complete direction at this point. Any suggestions?I have 4.5 bolt pattern.
he will chime in. Might be a full in box. Good guy to deal with.
Do you have redrilled small bolt axles? If so you need redrilled drums. If you have big bolt big brake axles you will need to run the 10x2.5 brake parts including backing plates.
It would be easier to go 10 x 2 1/2”. Your not going to find A body 10 x 1 3/4” drums with the large bolt pattern. Never made them.
Yes, I kind of figured that when I put my drums on tightened and no spinny. I have 2 1/2 drums with 1 3/4 shoes and backing plates
FWIW, I've had re-drilled rear drums since I've owned my '69.
Small register std 8-3/4
old drum / new drum......
New drum re-drilled.......
