kazooom
Hey Clint, looks like ya don't have to base ball bat the wheel wells anymore, now you need a bigger tire ha ha!!
Should be no reason (or gain) at all running straight 110 octane with just 10.5 to 1 compression
Should be no reason (or gain) at all running straight 110 octane with just 10.5 to 1 compression unless your running such a small cam that the DCR is real high or your engine is just not very efficient. My 408 is 9.98 to 1 compression with iron heads and the DCR is 8.22 and it runs at max with 89 octane. Higher octane burns slower. You want your cylinder pressure to peak at 12-15 degrees ATDC. If your using higher octane than you need the peak pressure will fall later which results in less power output
I run 14 / 32 all in @ 3200 11.4:1 , 190 cyl pressure , runs better with a mix of 1 gal 118 /3 of 94 , of course the 94 has ethanol , cannot find ethanol free 94 . And have a small cam . it runs on 94 , but does ping at times , not often , never with the mix of 118 .X2
I'd try a more docile timing curve if it really needs this fuel before I'd spend that kind of coin on gasoline.
I run 17/35 all in by 3500. 10.5:1, 160CPSI. 91-94 octane. It does prefer ethanol free.
Tracy you are right
Mine wants maybe 2 gallon per tank to keep it quite. The only reason I filled it up is my plan was to go south and this way I can put gas in a couple of times and still have some 110, or it will be stored for the winter and then don't have to worry about fuel separation.
It really should run on pump gas, have changed the tune, taken timing out and nothing helps.
Probably next year the engine will come back out, cam change, head change and hell might make it a stroker. Or do something completely different
It is a pain in the *** not being able to run on pump gas without fear of damage.
I did check into some octane booster, but the cost per quart is about equal to buying the race gas. The only good thing is being to drive where ever with a bottle of juice to keep going.
It's the late closing intake valve(ICA) that can make or break your combo. The static C/R is of importance,to be sure, but only insomuch as it is used to achieve a working Dynamic cr.
If you know the exact measured static C/R, and the exact ICA , the exact boreNstroke, and exact rod length, then it's possible to calculate the operating Dcr of the engine. From success stories, we know that an aluminum headed engine can successfully burn 87E10 on a Dcr of 8.5 to 8.8. And 93 octane will support a Dcr of 9.2. Iron heads need to reduce the Dcr about .5 to .8.All figures are corrected to sealevel. If you observe these parameters you will have success.
I like to push the limit, cuz I'm willing and able to put the tuning time into it.Plus I don't race my car, and so it spends very little time running on the edge where detonation lives.Plus I have a 360, which is a more than adequate street performer. If I was stuck with a smaller engine, it would have to work a lot harder, and then pushing the envelope could get expensive.If you need help with the Dcr calculation, you will need to obtain the exact figures, as noted above. Keep in mind that if your 340 has pop-up pistons in it, you will need compatible heads.
