130 or 143 tooth flywheel
70aarcuda
Master Hoader of SBM
Legendary Member
las vegas
Looking for a flywheel for my 70 340 Cuda....10.5 clutch...I believe it is a 130 tooth flywheel ...Am I correct ...Have not dealt with 4 speeds in 30 yrs...
I see this one but I dont think it will work...14.5 in diameter...my existing flywheel is 13 inches which I assume is 130 tooth because of the small diameter.
JEGS 601400: Flywheel for 1967-1993 Chrysler 318-440 with 6-Bolt Crank | JEGS
Thanks
Yes. passenger car is the lesser no. Larger tooth count is pickup/ van/ etc The bell you use must match flywheel count or starter will not engage.
Well...after measuring the bell housing..that is the wrong flywheel
Going to take old one to machine shop and see about surfacing it...
It will be a 130 tooth flywheel, the 143 were truck, and earlier big block flywheels.
