I'm not really concerned about a stock spicer yoke for a Dana, after seeing pulling trucks with 1000+ hp running cast yokes that held up extremely well. Usually they were 1410 or 1480 but a 1410 is the same but wider. Also I couldn't count how many times I have see burnt up u joints because of u bolt yokes. People over tighten them and they build heat. The strap design is more user friendly and spicer claimed they are stronger. The straps are designed to be a one time use and should be replaced every time they are removed.
