14 inch Rally wheels with Disc Brakes
jcsquare
Dallas
I just installed a front factory disc brake setup from a 1975 Duster onto my 1972 Duster that had drum brakes.
Will my stock 14 inch Rally wheels work on my new disc brake setup? Nothing is rubbing but I see very little clearance.
14" rally wheels should fit no problem, as long as they dont rub dont worry about it
does anyone have pictures of 14'' rally wheels with a stock disc brake setup? I was told that the caliper will heat up and expand thus causing the calipers to rub the wheel. I do not want to get rid of these wheels and new tires nor do I want drum brakes on the front.
BTW, i am new to Mopar.
I have the 10.8 inch disks and they clear my 14 inch ralleys with no problem, however, they don't clear my rear disk kit that I installed. Oh, well !
