SuperStock
I make this thread because I guess there are a lot members here will have a same question.
After doing some re-search finding the right combo tire for my Barracuda, SBP stock wheel, I come up with some question, hope you guy could help!
1) How wide the 14 inches rims could fit under 67 barracuda without any clearance issue? 14x6? 14x7?(I knew that widest factory steel rim is 14x5.5 @ FABO, :read2.
2) If I want to switch to bigger radius rim, such as 15 inches rim, can I just buy a sbp 15 inches rims and swap in?
And, which 15 inches rims will fit under this 67 barracuda without any modify? 15x6? 15x7? 15x8?
3) About the cop wheel, are they always BBP or they also have SBP?
***Pls note that I am not interested in Aluminum or Cargar or Custom make rim. So my choice would be either: Steel rims or Rally rims.
Thank so very much and Merry Christmas to you all!
You people are professional!
