Would like to find two (2) 14" x 6" or 7" (7" preferred) aluminum slot wheels with the 5 x 4" SBP to match two I already have. To match they need to have the push thru style center cap and not the screw on like most. My exsting pair are marked with "Cragar" as the manufacturer but all with push thru center cap style considered. 8" wide will not be considered as they are to wide for my low cut wheel well. Might sell my two if you can make a compelling case like last item needed to complete a decade long project or your wife will cancel divorce proceedings if you can get these for her. .
