15-piece Bi-metal Hole Saw Kit
Brad4406
Fairborn, OH
http://www.homedepot.com/p/Milwaukee-Metal-Hole-Saw-Kit-15-Piece-49-22-4027/206167001
I finally got tired of destroying wood hole saws on metal and decided to buy a metal hole saw kit. I was expecting to spend some decent money and never expected to find this deal. They are sold out on line so you have to call your local store to verify they have it and get it at the store.
I already used the 2" bit twice during my minitub for relocating some access holes to floor plugs and it worked great.
The whole trick to using these hole saws is to do two things....keep the RPMs low and use some lube. If you use low speeds the cutting edges will never overheat (burn up) and should last a very long time. If you use lube when cutting you can double or triple the life of the cutting edges!!
treblig
