15x10 steel wheel with 7.25" backspace?
Yes Mustang is same bolt pattern as mopar 5x4.5. And considering Mustangs are the most popular race cars the race cars mostly use 15". Not talking about factory wheels. Aftermarket off the shelf 15 x 10 7.25 BS
Also 2010 n newer challengers take the same offset n size. 18" Wheels on my car are newer Mopar as well. 18x8.5 fit better on the front than most aftermarket 15x5 since they always come with barely any offset. While the 18's are massive offset which most newer cars use. Benefits our cars as well. Worst case on some of them the center bore housings is smaller but easy to machine depending on which factory brakes are used. Aftermarket disk brakes can be had in any bore diameter. They also have the same in 17x10 or 8's
Guys use the new 5x100mm Mopar wheels for 5 on 4 cars, but they are not quite the same pattern, and a risky thing to do. There is excess strain on the studs, the lugs can work loose, or studs break, and have a wheel fall off or break.
If you are aware of the risks and go ahead, we'll then.......
