Unconventional
Big blocks are cool, no doubt. A 390 or 410 small block doesn't tip your hand .
I would not bother with trying to swap in a big block, if your looking for more power you can always build another small block 360 or something for a reasonable price. You can get a ton of power out of a small block without the hassle that you would go through to put in a big block. Just my opinion though...
It was the last year for push button, and the last year for ball and trunion driveshaft. In 65, they still used the two cable transmission, they made some changes. They went with a slip yoke drive shaft system, and on column shift cars, they went with an adapter for the cable on the steering column in the engine compartment. Console cars still used the same console, and shifter as used in 64. These trans are of interest to guys that want to eliminate the ball and trunion driveshaft, but keep the stock shifting mechanism.The last year for a push button trans, in a A-Body, and B-Body was 1964 -- not sure about the larger bodies, but I suspect that was the last year, for all.
Oh yeah, don't sell it when you turn 22 or get married..... you'll kick yourself for it for many years...........
Any idea on where would be a good place to try to sell the trany? (I am taking things in steps and selling tranny first before I make any other decisions)
As for power I don't see why every so anti big block but yes a good 360 is all you need.
My car has the 380 hp create which seems to dyno 400 hp plus and all it is basically a stock long block with cam 4bbl and headers pretty basic combo.
This... Budget build.., needs about a 3000 stall, and 3:70-3:90 gears, to make it really boogie....
Trust makes more than enough power to get your duster moving.
probably the best advice you'll ever get. start at the rear (with a plan) and work forward..If this is a budget build, stick with the 318 for now. Start with rear end and gears then headers and exhaust. Stock long block 318 with headers 4bbl and comps xe262h cam is said to make 282 hp good enough for a start. At this point probably build the tranny to handle the next stage in power with stall and shift kit. Now you can't get much more out of the 318 cause of heads so next step would be EQ's or edelbrock. Now you got all the go fast parts now it's time for the bottom end either 318/340/360 or there stroker versions.
