A Agent73 New Member Joined Nov 11, 2007 Messages 3 Reaction score 1 Nov 13, 2007 #1 I would like to use American Racing Torque Thrust II 17x8 4.5 backspace 0 offset front and rear. Will this work on my stock 73 Duster?
black betty Well-Known Member Joined Oct 11, 2005 Messages 170 Reaction score 42 Location Bainbridge, PA Nov 14, 2007 #2 That size will fit. I had 17x9 on the front of my Dart but I dont remember what the backspacing was.
T tobysoldblue tobysoldblue Joined Aug 4, 2007 Messages 1,314 Reaction score 11 Location mount olive,nc Nov 29, 2007 #3 i put 17 by 8s on mine
D darthcoods1 Member Joined Oct 31, 2007 Messages 9 Reaction score 0 Dec 9, 2007 #4 toby, what is your backspacing, offset and tire size. Thanks!
autoxcuda Well-Known Member Joined Apr 6, 2007 Messages 9,061 Reaction score 4,173 Dec 10, 2007 #5 with 17x9 you need about 5.62 or 5.5 backspacing. Here's a Valiant with the same 17x8 and 5.62 backspacing as pictured above. Some rims come closer to the outer tie rod than others. You need the flat upper ball joints though. http://www.moparfins.com/CLAIRDAVIS/1969_front_end.htm http://www.moparfins.com/CLAIRDAVIS/Cobra_Wheel.htm
