I contacted the manufacturer about this very issue. My pistons are machined for 18 degree valve angle, and I was looking into purchasing Indy heads. I couldn't find the info on line about the valve angle, so I called the piston manufacturer to clarify and they told me if the valve angle in the head is different from that of the piston, there will be issues.
You can still go ahead and clay it, but I doubt it will work...of course, I don't know everything though...I do know I wouldn't want to try though and have issues.
In regards to the mythical victors, one of the parts they would require is custom pistons from all the reading I am doing because of the valve angle, which is part of why they seem to be a niche piece so to speak
