GMachineDartGT
Senior Member
18s in the sig.
I agree, I am a fan of 17's myself. BUt I would love to see pics of 18's.
Here is 5258's:
Ihave no issues with big wheels on old cars, I plan on big wheels on my abody. What it comes down to to me is it's ether the correct bolt pattern or it isn't end of story in my mind.While I welcome the debate on the subject, my earlier thread on the issue covers everything that's being talked about in here:
http://www.forabodiesonly.com/mopar/showthread.php?t=74008
I've got 5x115 wheels on my 5x114.3 Intrepid, and if you center the wheels properly on the lugs/hubs, you dont have any problems with them. Two 2000 mile round trips to Pennsylvania and an additional 10000 miles on the car since I put the wheels on it prove that beyond a reasonable doubt to me.
I know you guys are mostly old school, but having done this already and played this game, I've learned a lot about it and I've got plenty of confidence in putting these wheels on my Dart.
Moving on, lets post some damn pictures of these A's with 18s!
18s in the sig.
4.5" = 114.3mm. Exactly. That is the conversion, no rounding, feel free to try it yourself.
1"=25.4 mm. 4.5 x 25.4 = 114.3
Any wheel advertised as 5x114.3 will fit the bolt pattern for LBP mopars.
5x115mm will not unless you open up the bolt holes, I wouldn't do it myself, but I'm sure its been done.
there is a guy running around here with a hemicuda with widened steel charger wheels on it. it looks pretty good and hes taken it on power tours. he had no issues. it crossed my mind but the mustang rims worked out like they belong. almost.
Never Mind the fact that the Charger Wheels are a Front wheel drive positive offset and the Hub centric rings are about a 1/2 inch larger then the a bodies. so you will need hub centric ring adapters and the 5x114.3 lug pattern needs to be redrilled to 5x4.5
Sorry for the quality of the screen shot. This is a converter program I have and it is pretty handy. Trying to get it saved as a good jpg is not easy. The 114.3 pattern is essentially the same as a 4.5" bolt pattern. it is actually 4.499986" using the converter. That is about as close to 4.5" as you can get
on the boss wheels which back spacing did u go with i have a 74 duster and those are the ones i wanted to run on mine i was thinking about a 18 20 combo but not sure which ones will fit! Can u please help me out!
well explain to me how a 5x4.5 wont fit on an LX without Hub Centri rings and having the Lug nut sit at the outer edge of the lug hole. (Seen with my own eyes stud ripping off of a charger because his drag slicks were 5x4.5) There is a difference it might be slight but it's there and for me I'd rather have the right lug spacing then risk my life to save a couple bucks.The 5 x 114.3 is the same as 5 x 4.5
I can't speak from experience, but I've been looking at rims for my 74 Duster as well and have done a fair amount of research so I will tell you what I know.
First, I think about 4" is the minimum sidewall for a tire based on my experiences with replacing tires on my wifes PT and what I seen other people be successful with. This is what I consider the foundation for a wheel and tire selection.
Kenny Wayne Shepherd ran an 18/19 combo on his Duster, and the front tires only had about 3.5" of sidewall in the front and a little less than 4" in the rear with 225/40 and 285/35 tires. The max diameter that seems to fit in the front is about 26, so you could run maybe a 225/45 or a 255/40 tire in the front. I've seen some that have run a 28" diameter tire in the rear, so you could go with a 285/35R20 in the rear and probably make it work.
Myself, I think 18 and 20 is too big for the car, but I haven't seen that setup either.
I am thinking 17 and 18, myself. Probably a 245/45R17 and 275/40R18 as there seems to be a wide selection of tires and the rims are easy to get. Might go 275/40 in the front as well, but still 17 as I think the bigger haunches of the Duster look better with a stagger. Time will tell.
For wheels, I have been looking at the ones from AmericanMuscle.com. They are comparatively inexpensive and have a wide selection that fit. Probably something in a 17x8 with a 30mm offset for the front and an 18x9 with a 24mm offset in the rear. If I go with a 275 tire in the front I will use a 17x9 wheel with a 24mm offset.
Either front wheel should fit without a hassle (other than hub interference), but the rear will require a wider axle of some type. Not a big fan of spacers but something like a 1/4" one to clear the springs doesn't bother me as it isn't really any different than a disk rotor. An A-Body 8.75 with BBP axles is wider than a SBP one, and the 18x9 wheel should fit fine if I move the springs in with the relocation kit. Wracks71 on here did it with 17x9 wheels with the same offset and 3/8" spacers and didn't move the springs but it was a little tight. Other options are an early B-Body axle, or maybe a later (like '69) one with a wheel that has a bit more positive offset.
Still working it out, time will tell.
Might look at this thread, there's a wealth of info there on 17" wheels that might help.
Front 205-50-17 on 17 x 7" Billet specialties, rear 285-40-18 on 18 x 10" both tires have 4" of sidewall.
