wildturkey
Member
I am on the hunt for a carb rebuild kit for the 1920. I was in touch with Walker today trying to get a number for my local Orielly. The numbers on my carb is 12R-4328B and they both say they have no info on that carb number. The carb is clean and the numbers are very easy to make out so now Im at a standstill. There also is some numbers on top of the float bowl 0690 with 43 under that. Thanks for any help you can give. I also would like to replace the float at the same time and it seems from looking around the 58 jet is the one to get for decent fuel economy....any thoughts on this to?
