/6 Matt
30 Degrees Crooked
Can anyone tell me what the economizer valve on a holley 1920 does? What is its purpose.?
I know you can find photos here if you search the fuel forum. There are 2 fingers on plastic lever that the vacuum actuation rod acts upon, which open spring-loaded ball ports at different times, hence the "2 stage". It richens the mixture at high throttle for more power when needed. The "economy" is when it closes. Same idea as the "power valve" in 4 bbl Holley's, but not replaceable (for tweaking), and I haven't heard that it is damaged by back-fire like power valves often are.
